PLASTIC SHEETS - SOLID SURFACE - NON-FERROUS - NESTED BASED - COMPOSITES
High-performance three axis for nested-based applications
The Model 43 is built to handle a wide range of materials and applications, boosting your shop's efficiency, material yield, and overall profitability.
With table sizes up to 5'x20' and integrated Control Nesting software, you can process full-sized sheets with optimized layouts to reduce waste.
A powerful 12 HP spindle and rapid indexing speeds of 2,800 IPM mean you can produce more parts in less time without sacrificing quality.
Features like automatic tool changing, laser-compensated axis alignment, and the robust Thermwood SuperControl ensure every job is accurate and repeatable.
High-performance three axis made from fully stress-relieved structured steel for nested-based custom cabinets, custom furniture, plastics, composites and other support products.
Available Table Sizes: 4'x8', 5'x10', 5'x12', 5'x20'
Standard Tool Pickup Positions: 10 (4'x8'), 12 (5'x10'), 12 (5'x12'), 11 (5'x20')
5'x10' & 5'x12': dual pipe dust collection, expandable up to 21 tooling positions
5'x20': expandable to 21 tooling positions with optional 10 position rotary tool changer
Speed: Indexes at 2,800 IPM Standard
Complete nested-based CNC routing system with SmartRouter Technology, designed for custom cabinet, closet, and furniture builders. Ideal for producing cabinet and closet boxes, drawer boxes, doors and drawer fronts, and custom moldings.
5'x10' (with 21 tooling positions standard and dual pipe dust collection)
What would a Work Cell save your shop?
Enter your crew size, cycle, labeling and unload times, and see your cost per sheet today side by side with a one-operator Model 43 Work Cell.
Try the Free Savings CalculatorSpeed: Indexes at 2,800 IPM Standard
| Specification | Model 43 | Model 43 Work Cell |
| Core Performance | ||
| Table sizes | 4'x8', 5'x10', 5'x12', 5'x20' | 5'x10' only |
| Machine design | Fixed steel high-flow table with moving gantry | Fixed steel high-flow table with moving gantry |
| Frame | Fully stress-relieved structured steel | Fully stress-relieved structured steel |
| Spindle | 12 HP HSD, 3,000 to 24,000 RPM | 12 HP HSD, 3,000 to 24,000 RPM |
| Indexing speed | 2,800 IPM standard | 2,800 IPM standard |
| Vacuum | Universal vacuum, 1 or 2 zones | Dual high-flow vacuum zones |
| Dust collection | Dual pipe on 5'x10' and 5'x12' | Dual pipe |
| Automation & Efficiency | ||
| Tool pickup positions | Bar style: 10 (4'x8'), 12 (5'x10'), 12 (5'x12'), 11 (5'x20') | 21 positions standard, bar style |
| Tool length measurement | Automatic | Automatic, high tolerance |
| Pop-up pins | Automatic, programmable | Automatic, programmable |
| Nesting software | Control Nesting | Control Nesting |
| Part unloading | — | Full-table off-load rake with integrated dust collection |
| Out-feed conveyor | — | Powered, 61" x 144" |
| Personal pause fob | Optional | Included |
| Lubrication | Optional automatic lubrication | Automatic lubrication system |
| Precision & Control | ||
| Axis alignment | Three-dimensional laser compensated | Three-dimensional laser compensated |
| Servo drives | Intelligent servo drives throughout | Siemens intelligent servo drives throughout |
| Control | Thermwood SuperControl with SmartRouter Technology | Thermwood SuperControl with SmartRouter Technology |
| Support & Training | ||
| Training | Machine training and installation | Machine training and installation |
| Support | Free lifetime phone, forum and email support; lifetime machine support | Free lifetime phone, forum and email support; lifetime machine support |
| Available Options | ||
| Additional tool positions | 5'x10' and 5'x12': add positions in increments of 3, up to 21 total 5'x20': add a 10 position rotary tool changer, for 21 total |
| Unloading | Unload rake system; full-table rake with integrated dust collection (4'x8' and 5'x10') | — |
| Sheet loading | — | Manual lift system with automatic sequence light sheet locator |
| Operator safety | Personal pause fob; pause mats | — |
| Remote operator station | — | Touch screen monitor and label printer |
| Labeling | Automatic labeler | — |
| Lubrication | Automatic lubrication system | — |
The Thermwood Model 43 is a high-performance three-axis nested-based CNC router designed for custom cabinets, closets, custom furniture, plastic sheets, solid surface, non-ferrous metals, and composites.
The Model 43 is available in four table sizes: 4'x8', 5'x10', 5'x12', and 5'x20'. Standard tool pickup positions are 10 on the 4'x8', 12 on the 5'x10' and 5'x12', and 11 on the 5'x20'. The 5'x10' and 5'x12' include dual pipe dust collection and can add tool positions in increments of 3, up to 21 total. The 5'x20' can add a 10 position rotary tool changer, for 21 total positions. The Model 43 Work Cell is always a 5'x10'.
The Thermwood Model 43 indexes at 2,800 IPM (inches per minute) as standard, allowing for high-speed production without sacrificing quality.
The Model 43 features a 12 HP HSD Spindle with a speed range of 3,000 to 24,000 RPM.
The Model 43 Work Cell is a complete nested-based CNC routing system with SmartRouter Technology designed for custom cabinet, closet, and furniture builders. It includes a 21 position automatic tool changer, powered out-feed conveyor, and full table off-load rake with integrated dust collection. An optional remote operator station adds a touch screen monitor and label printer. It is available in a 5'x10' table size.
It depends on your crew size, cycle times and labor rate. The free Model 43 Work Cell Savings Calculator compares your current process with a one-operator Work Cell and estimates your cost per sheet, savings per sheet and yearly savings. Its example shop, running 2 people per machine with a 5.5-minute program cycle time, saves about $9.43 per sheet.
Yes. Every Thermwood Model 43 includes machine training and installation, plus free lifetime phone, forum, and email support backed by Thermwood's legendary service and support team.
