PLASTIC SHEETS - SOLID SURFACE - NON-FERROUS - NESTED BASED - COMPOSITES
CABINETSHOP 43
High-performance three axis for nested-based custom cabinets, custom furniture and support products
CABINETSHOP 43
High-performance three axis made from fully stress-relieved structured steel for nested-based custom cabinets, custom furniture and support products.
Available Table Sizes:
4'x'8', 5'x10', 5'x12', 5'x20'
  • 12 HP HSD Spindle (3,000-24,000 RPM)
  • 11 Position Bar Style Automatic Tool Changer
  • Fixed Steel High Flow Table with Moving Gantry
  • Universal Vacuum 1 or 2 Zone(s)
  • Automatic Tool Length Measurement
  • QCore SuperControl
Request More Info Brochure Free eBook CNC Investment Calculator
Machine Standard Features
  • 12 HP (9kw) Spindle
    12 HP (9kw) Spindle
    A direct driven spindle with a speed range up to 24,000 RPM.  The high-frequency spindle is cooled with an electric fan for quieter running and contains ceramic bearings for longer life and for less maintenance.  The 12 HP (9kw) spindle provides the user with a heavy duty, precision spindle which provides high performance and reliability. Standard
  • Pop-Up Pins
    Pop-Up Pins
    Guides mounted to the table perimeter for locating sheets of material.  They are flipped to the up position to lacate the material and then retracted to clear during the machining cycle. Standard
  • Bar Style Automatic Tool Changer
    Mounts behind the rear of the table and holds the tapered tool holders.  When the program calls for a tool change, the head moves back and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Standard
    Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Standard
  • Machine Training
    Machine Training
    QCore SuperControl
    Control Nesting
    A user-friendly nesting package integrated into the Thermwood control to nest various parts into sheet stock, thus creating a better yield. Also accepts layered DXF files.  Standard
Machine Options
  • Unload Rake System
    Unload Rake System
    This system is mounted directly to the side of the spindle.  After the trimming process is complete, the machine head moves to the back of the machine and the rake is lowered.  The rake then pushes the finished product off the front of the machine to a sorting table Optional
  • Personal Pause Button
    Thermwood has developed a remote wireless "Pause Button" which can be clipped to a belt or pocket.  Pressing this button stops the machine in place. Optional
  • Pause Mats
    Pause Mats
    Placed around the front perimeter of the machine.  Once the mat is stepped on, the machine will stop operation. Optional
  • Automatic Labeler
    Automatic Labeler
    Prints black and white labels for the nested program and automatically labels the material prior to machining. The printer is located next to the machine and the labeler is mounted on the machining head. Optional
  • Vacuum Pump
    Vacuum Pump
    Universal Vacuum System is a unique method for holding panels to the table top for machining.  A sheet of particleboard or low density MDF is used as a work surface on the top fo the table.  The high flow pump vacuums through the work surface, holding the part to the table.  Pumps are available as 15HP (11kw).  Conventional vacuum also available. Optional
  • Custom Colors
    Custom Colors
    The Model 43 is available with any of five accent colors on the transparent tooling shield and control side panel.  A sheet metal control side panel (in painted machine color) is also available in place of the accent-colored control side panel. Optional
  • Automatic Lubrication
    Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Optional
Videos
Thermwood Model 43 Label/Cut/Unload - Full Sequence
Thermwood CabinetShop 43 Import DXF/Create CNC Program
Thermwood Model 43 Unload
Thermwood Model 43 - Solution for Nested Based Cabinet Production
Thermwood Model 43 with Auto Labeling
Thermwood Model 43 5'x10' with Auto Unload System
Thermwood Model 43 Machining Small Parts in UHMW
Thermwood Model 43 Machining Acryllic and Plastic Sheets
Thermwood Model 43 - Smart Routers Machine a Profile Edge Without a Profile Tool
Model 43 - Smart Routers Allow You To Machine Back Side Operations on the Full Sheet
Thermwood Model 43 - Recover From Broken Tools Without Scrapping Material
Thermwood Model 43 - Smart Routers Easily Use Material From the Last Job
Thermwood CabinetShop 43 Making a Dovetail Drawer Box
Thermwood Model 43 Modeling MDF Doors
Thermwood CabinetShop 43 Carving Applications
Thermwood CabinetShop 43 Cabinet Cutting
