LSAM Large Scale Additive Manufacturing (LFAM) Systems | Thermwood
LSAM
Advanced industrial “Near Net Shape” production systems capable of printing and trimming on the same machine. Engineered to create fixtures, high-temp molds, tooling, prototypes, and end products from a wide range of materials.
Featured Videos
Thermwood LSAM: A Game-Changer for D-J Engineering ▶
With their Thermwood LSAM MT, D-J Engineering produces complex tooling in weeks instead of months, making the process faster, predictable, and repeatable.
Thermwood LSAM and Purdue University: Shaping the Future of Composites Manufacturing ▶
Dr. Byron Pipes and Dr. Eduardo Barocio explain how their Purdue collaboration with Thermwood LSAM is driving large-scale 3D printing and industrial composites innovation.
Revolutionizing Large Scale Manufacturing
LSAM is engineered to dramatically accelerate production, reduce costs, and unlock new possibilities in large-part manufacturing.
Unprecedented Scale
Build massive parts and tools with print beds available up to 40 feet and beyond, enabling manufacturing on a scale previously thought impossible.
Two Processes, One Machine
Go from a printed near-net-shape part to a final, trimmed, high-precision product on a single machine, streamlining your workflow.
High-Temp Polymers
Process virtually any composite thermoplastic, with temperatures up to 450°C to produce strong, durable, and reliable parts for demanding applications.
Standard LSAM Flagship (Closed Configuration)
These are near net shape additive manufacturing systems that offer both print and trim on the same machine. They are configured with a fixed table, high walls, and a moving gantry or gantries, and can be fully enclosed to meet CE requirements.
Available Sizes: 10'x10', 10'x20', 10'x40', 15'x20', 15'x40'
The model numbers (1010, 1020, etc.) denote the table size in feet. While 40-foot lengths are common, even longer machines are possible.
Gantry & Control System
  • Models 1010, 1020, 1040,1520, 1540: Dual gantries and dual controls, one for printing and one for trimming. This allows simultaneous printing on one end of the table while trimming on the other.
Advanced Capabilities
  • LSAM Flagship models can be equipped with a VLP System. (This system enables printing parts as tall as the machine table is long on a moving vertical table.)
  • Machines 1010 and larger can be equipped with an Angle Layer Print System. (This system enables printing parts at a 45° angle.)
LSAM MT (Open Configuration)
This machine is configured with both a print and trim head on a single fixed gantry mounted overa 10'x10' moving table. This system can both print and trim, but not at the same time.
Key Features
  • Features a 10'x10' primary working area (max vertical build of 5').
  • An additional two feet of table length accommodates an optional Vertical Layer Print Table, allowing parts up to ten feet tall to be printed vertically.
  • Utilizes the same powerful print and trim heads as all other LSAM machines.
  • Also available as an optional "Print Only" machine for those with existing trimming capabilities.
  • LSAM MT 1010 can be equipped with a VLP System. (This system enables printing parts as tall as the machine table is long on a moving vertical table.)
LSAM Additive Printers
"Print Only" systems built around Thermwood's 40mm LSAM print head, offering highly capable machines at an attractive price point. These systems feature a single gantry, moving table configuration.
Available Table Sizes: 5'x5', 5'x10' or 10'x5'
Configurations & Capacity
  • The 5'x10' table is available as 5' wide with 10' motion or 10' wide with 5' motion.
  • Standard single servo table drive accommodates parts up to 1,000 lbs.
  • An optional second table drive increases max weight capacity to 2,000 lbs (10' wide table only).
  • The 5' wide by 10' deep version supports Vertical Layer Printing for parts up to 10 feet tall.
Core Technology
  • Uses the exact same print head and advanced Ultra 6 control as the largest LSAM systems.
  • A rigid, structural steel gantry incorporates a fume extraction system with activated charcoal filters.
  • Standard single hopper polymer dryer; dual hopper dryer available as an option.
  • A full machine enclosure is available, allowing the machine to meet European CE standards.
  • LSAM AP 510 can be equipped with a VLP System. (This system enables printing parts as tall as the machine table is long on a moving vertical table.)
What is LSAM?
LSAM (pronounced L-Sam) represents the industry-leading technology for large scale 3D printing of thermoplastic polymers. It utilizes unique patented technology to produce the highest quality printed structures available.
LSAM Series Machines
LSAM uses the "Near Net Shape" approach to part production where the part is first printed at high speed slightly larger than needed, then trimmed to the final size and shape. This is the fastest, most efficient method of 3D printing large structures. With LSAM, both printing and trimming can be done on the same machine.
LSAM can process parts from virtually any thermoplastic composite material including high temperature materials that are ideal for molds and tooling. Its unique printing system produces parts that are solid, fully fused, vacuum tight and virtually void free, making it a full-fledged industrial additive manufacturing system intended for serious production.
Every Layer Has a Deadline
On a large-format print, the strength of a tool comes down to what happens where each layer meets the next. If a layer finishes too quickly, the one beneath it is still too hot to support it. If it takes too long, that layer cools past the point where the next one can fully bond. Either way, you end up with a weaker tool. LSAM gets this right with two technologies working together.
Layer Time Control: The Right Temperature
Layer Time Control keeps every layer in the right temperature range for bonding, automatically. It sets a minimum time for each layer group and adjusts feed rate to match, and an onboard thermal camera confirms print temperatures as each layer goes down.
  • Built into the LSAM control system
  • Automatically adjusts print speed to control the time spent on each layer
  • Keeps the print at an optimal temperature, in real time
  • Can be adjusted immediately, even while the machine is printing
  • Onboard thermal camera gives visual confirmation of print temperatures
  • Optimal temperature range means better, more consistent layer fusion
Patented Compression Wheel: The Right Pressure
The nozzle sits slightly above the finished bead height, and Thermwood's patented compression wheel follows right behind it. The wheel presses each bead into its final shape and dimension and compacts it into the layer below.
  • Removes inter-bead voids
  • Improves consistency in printed composite microstructures
  • Enhances interlayer bonding
  • Enhances lateral bead-to-bead bonding
Close-up of an LSAM nozzle and compression wheel laying uniform printed layers
Uniform beads, tight layers, and solid fusion, pressed into place by the compression wheel.
Request More Info
The LSAM Difference
Part printed on LSAM's Patented Bead Board
The LSAM Print Process
LSAM prints a large bead at room temperature in a process which is an exercise in controlled cooling. A patented compression wheel totally fuses layers together, creating solid, virtually void-free structures that can sustain vacuum in an autoclave without add-on coatings.
  • Patented "Bead Board" virtually eliminates warping.
  • Compression wheel ensures superior layer fusion.
  • Precise bead dimensions measured in thousandths of an inch.
LSAM machines are built from steel plate using slot and tab construction
Robust Industrial Machine Design
LSAM machines are large, robust industrial structures built from fully annealed steel plate using slot-and-tab construction. This results in an order of magnitude higher strength and stiffness than typical machine construction. The entire machine is volumetrically compensated for superior accuracy.
  • Dual gantries for simultaneous printing and trimming.
  • Laser-aligned and compensated on all axes.
  • Configurations available up to 100 feet in length.
Based on Thermwood's SuperControl
The Thermwood SuperControl
The LSAM control provides unique functions to make the print process easier and more capable. It automatically synchronizes the melt pump output to machine speed for perfect bead dimensions, and orients the compression wheel to the direction of motion, eliminating the need for complex programming.
  • Fully integrated temperature and pressure controls.
  • Automatic layer time control for consistent prints.
  • Simple, one-button operation for complex functions.
Thermwood's LSAM Print 3D is a true CAD slicing software that works within Mastercam.
Industry-Leading Slicing Software
To address the lack of professional software for "Near Net Shape" printing, Thermwood developed a true CAD slicing software that works within Mastercam. It accepts geometry in every major CAD format and offers powerful, feature-rich programming capabilities.
  • Automatically adjusts for unique machine print characteristics.
  • Allows solid or sparse infill, variable boundary layers, and more.
  • Programs incredibly complex parts by printing concurrent structures.
Learn More
This video details why LSAM has become the obvious choice for large scale additive systems operating in industry.
This book explores, in everyday language, all aspects of large scale additive technology used in industrial production today.
A Manager's Guide to Large Scale Additive Manufacturing
LSAM Frequently Asked Questions
What is Thermwood LSAM?
LSAM (pronounced L-Sam) is Thermwood's large scale additive manufacturing system and the industry-leading technology for large scale 3D printing of thermoplastic polymers. It uses a patented Near Net Shape process where a part is first printed at high speed slightly larger than the final dimensions, then trimmed to final size and shape, with both printing and trimming available on the same machine. LSAM produces solid, fully fused, vacuum-tight, virtually void-free structures suitable for serious industrial production.
What sizes are available for the Thermwood LSAM?
The LSAM Flagship is available in 10'x10', 10'x20', 10'x40', 15'x20', and 15'x40' configurations, with even longer machines possible. The LSAM MT is available with a 10'x5' or 10'x10' moving table. The LSAM Additive Printer is available in 5'x5', 5'x10', and 10'x5' configurations.
What is the difference between LSAM Flagship, LSAM MT, and LSAM Additive Printer?
The LSAM Flagship is a closed configuration system with dual gantries and dual controls, allowing simultaneous printing on one end of the table while trimming on the other. It is the most capable and largest configuration. The LSAM MT is an open configuration system with a single gantry that has both print and trim heads. It can print and trim but not at the same time, and is available in 10'x5' and 10'x10' table sizes. The LSAM Additive Printer is a print-only system built around Thermwood's 40mm LSAM print head at an attractive price point, available in smaller table sizes for operations with existing trimming capabilities.
What materials can the Thermwood LSAM print?
The LSAM can process virtually any thermoplastic composite material, including high-temperature materials at up to 450°C. This includes carbon fiber-reinforced polymers, ABS, Ultem, PPS, PESU, and other engineering thermoplastics used for molds, tooling, fixtures, and production parts.
What is the Near Net Shape process used by LSAM?
Near Net Shape is LSAM's approach to part production where the part is first printed at high speed slightly larger than the final dimensions, then trimmed to final size and shape. This is the fastest and most efficient method of 3D printing large structures. LSAM's patented compression wheel totally fuses layers together creating solid, virtually void-free structures that can sustain vacuum in an autoclave without add-on coatings, while the patented Bead Board virtually eliminates warping during printing.
What is the VLP System on the Thermwood LSAM?
The VLP (Vertical Layer Print) System is an advanced option available on select LSAM models that enables printing parts as tall as the machine table is long on a moving vertical table. This significantly expands the vertical build envelope beyond the standard machine height.
What industries use the Thermwood LSAM?
The LSAM is used across industries requiring large-format additive manufacturing including aerospace tooling, automotive tooling and fixtures, marine component manufacturing, wind energy, military and defense, foundry patterns, composite layup tools, and industrial prototype and production applications.
What software does the Thermwood LSAM use?
LSAM uses Thermwood's LSAM Print 3D, a true CAD slicing software that works within Mastercam. It accepts geometry in every major CAD format and offers powerful programming capabilities including solid or sparse infill, variable boundary layers, and the ability to program complex parts by printing concurrent structures. The software automatically adjusts for the machine's unique print characteristics.
