Thermwood Video Showcase
Model 43
CabinetShop 43 4'x8' shown
Entry level three axis for nested-based custom cabinets, custom furniture and support products
Thermwood Model 43 Label/Cut/Unload - Full Sequence
Thermwood CabinetShop 43 Import DXF/Create CNC Program
Thermwood Model 43 Unload
Thermwood Model 43 - Solution for Nested Based Cabinet Production
Thermwood Model 43 with Auto Labeling
Thermwood Model 43 5'x10' with Auto Unload System
Thermwood Model 43 Machining Small Parts in UHMW
Thermwood Model 43 Machining Acryllic and Plastic Sheets
Thermwood Model 43 - Smart Routers Machine a Profile Edge Without a Profile Tool
Model 43 - Smart Routers Allow You To Machine Back Side Operations on the Full Sheet
Thermwood Model 43 - Recover From Broken Tools Without Scrapping Material
Thermwood Model 43 - Smart Routers Easily Use Material From the Last Job
Thermwood CabinetShop 43 Making a Dovetail Drawer Box
Thermwood Model 43 Modeling MDF Doors
Thermwood CabinetShop 43 Carving Applications
Thermwood CabinetShop 43 Cabinet Cutting
Model 45
Model 45 5'x10' shown
Heavy-duty three axis designed for nested-based production. Available in either single or dual spindles with optional rotary axis.
Thermwood Model 45 5'x10' Machining Foam Board
Thermwood Model 45 5'x10' Machining Variety of Rubber with Oscillating Knife
Thermwood Model 45 with Benz Oscillating Knife Machining Foam
Thermwood Model 45 with Reciprocating Knife Machining a Variety of Materials
Thermwood Model 45 5'x10' Machining Aluminum Sign
Thermwood Model 45 5'x10' Machining Aluminum Blank
Thermwood Model 45 5'x10' Machining An Aluminum Pyramid
Thermwood Model 45 5'x10' Machining Plastic Sheet (HDPE)
Thermwood Model 45 5'x10' Machining Carbon Fiber Reinforced Plastic
Thermwood Model 45 5'x10' Machining UHMW and Nylon
Thermwood Model 45 5'x10' Machining Phenolic Sheet
Thermwood Model 45 5'x10' Machining Small Plastic Parts with Hi-Flow Vacuum
Thermwood Model 45 5'x10' Cabinet Cutting
Thermwood Model 45 5'x10' Solid Wood Projects
Thermwood Model 45 with Nemi Pod System Machining Poplar Hardwood Door
Machining Various Chair Components on a Thermwood Model 45
Thermwood Model 45 Machining MDF Doors
Thermwood Model 45 Machining A Pattern
Model 53
Model 53 5'x20' shown
Moving gantry, fixed table, three-axis CNC router designed for the routing and stack machining of large sheet materials such as hardwoods, softwoods, fiberboard (MDF), particleboard, plastics and aluminum.
Thermwood Model 53 (FrameBuilder) 5'x10' with Auto Load/Unload
Thermwood Model 53 (FrameBuilder) 5'x20' With Roller Hold Down
Model 63
Model 63 5'x20' shown
Large bed three axis CNC router with moving bridge & stationary table designed for two dimensional machining of large composite parts & three dimensional patterns.
Thermwood Model 63 5'x45' Machining Aluminum
Cut Center
Cut Ready Cut Center 5'x10' shown
Award winning machine for custom cabinets, closets, furniture and much more with No Programming!
Cut Center Impressions - AUM Wood Products
Cut Center Impressions - Timberwood Properties
Cut Center Impressions - Original Woodworking
Cut Center Impressions - Byrne Custom Woodworking
Cut Center Impressions - Bednark Inc.
Cut Center Impressions - Arkansas Wood Doors
Learn How Simple it is to Machine a Cabinet Job on the Cut Ready Cut Center
How to Design a Cabinet and Add it to the Job in Cut Ready
Take a Tour of the Cut Ready Cut Center
What is the Difference Between a Cut Center and a CNC Router?
Cut Ready by Thermwood
About the Cut Center
Thermwood Cut Center Cuts Capabilities
Thermwood Cut Center Mobile App
Thermwood Cut Center Virtual Demo - Machining a Mitered Box
Thermwood Cut Center MDF Doors with Profile Tooling
Thermwood Cut Ready Publisher
Thermwood Cut Center Machining MDF Doors - Clip
Thermwood Cut Center Stair Stringers
Thermwood Cut Center Machining Bedroom Set
Thermwood Cut Center Making Cabinets
Thermwood Cut Center Machining Conference Room Desks
Thermwood Cut Center Machining Display Cabinet
Thermwood Cut Center Flipper in Action
MTR
MTR 30 Dual Table 5'x10' shown
Complete three axis CNC routing systems with single or dual in-line tables for nested base, composite or plastic sheet material.
Thermwood MTR 30-DT Three Axis Machining Center
AutoProcessor
AutoProcessor 7'x12' shown
High-throughput automatic load/unload nested based production of cabinets, closets and custom furniture.
Thermwood AutoProcessor 7'x12' CNC Router
Thermwood AutoProcessor 5'x10' CNC Router
FrameBuilder
FrameBuilder 48 4'x8' shown
Moving gantry, fixed 4'x8' table, with 4-roller hold down, three-axis CNC router. Designed for routing and stack machining of large sheet material such as fiberboard (MDF), particleboard and plywood.
Thermwood FrameBuilder 48 4'x8' Demo
4Nqum8fuKIE
Thermwood FrameBuilder 53 5'x10' with Auto load/unload
Thermwood FrameBuilder 53 5'x20' with Auto Unload
MTR
Thermwood APM 6'x10' shown
Designed for quick panel insertion for the aerospace and satellite industries
Thermwood APM - Automatic Panel Machine
Model 67
Model 67 Dual Table 5'x10'
Entry level five axis available with either single or dual moving aluminum tables.
Thermwood Model 67 Large Scuptures at John Cox's Creature Workshop
Thermwood Model 67 5 Axis CNC Trimming Plastic
Thermwood Model 67 Gantry Leg Tool Changer
Model 90
Model 90 Dual Table 5'x12' shown
Heavy-duty, high-speed trimming and pattern machining, available in single or dual moving aluminum tables
Model 90 5'x5' 5 Axis CNC Router Machining Medium Density Foam Tray
Thermwood Model 90 Machining Bust in Low-Density Foam
Thermwood Model 90 Modeling Foam and RenShape
Thermwood Model 90 Dual Table 5'x5' CNC Router Cutting HD Foam
Model 90 5'x5' 5 Axis CNC Router Machining Carbon Fiber Prosthetic Component
Thermwood Model 90 Dual Table 5'x'5 Machining Honeycomb
Thermwood Model 90 10'x5' 5 Axis with 10 Position Automatic Rotary Tool Changer
Thermwood 5 Axis Model 90 Dual Table 5'x5' Machining Aluminum
Thermwood Mastercam Solidworks Walkthrough Machining Aluminum Shield on 5 Axis Model 90
Thermwood 5 Axis Model 90 Dual Table 5'x5' Aluminum Machining
Model 90 5'x'5 5 Axis Plastic Trimming
Machining a bar stool seat bottom on a Thermwood Model 90
Model 90 5 Axis CNC Machining Pattern
Model 70
Model 70 10'x20' shown
Designed for aerospace and composite applications utilizing large/heavy fixtures
5 Axis Demonstrations
Thermwood Model 70 10 Position Rotary Automatic Tool Changer
Thermwood Model 70 Continuous C-Axis Rotation Modeling
Model 77
Model 77 10'x10' with Canopy Shown
Heavy-duty, high-speed contained system for the machining of large aerospace and composite materials.
Thermwood Model 77 10'x10' CNC Machining
Thermwood Model 77 10'x10' CNC Machining Center
Thermwood Model 77 10'x10' Composite Video
Thermwood Model 77 5 Axis Pattern/Modeling RenShape
Thermwood Model 77 10'x10' 5 Axis CNC Router
Thermwood Model 77 5 Axis Motions
Thermwood Model 77 10'x10' CNC Machinine Carbon Fiber
LSAM
Thermwood LSAM 10'x20' - Large Scale Additive Manufacturing System
Large industrial additive manufacturing machines that print and trim on the same machine.
Why LSAM?
Announcing the Thermwood LSAM Additive Printer
Take a Tour of the Thermwood LSAM
Thermwood and General Atomics Partner on Additive Tool with Significant Cost Savings
Thermwood LSAM MT VLP (Vertical Layer Printing) High Temperature Demonstration
Thermwood LSAM 1020 printing a Multi-Piece Foundry Pattern
Thermwood Introduces the LSAM MT
Thermwood and Bell 3D Print Helicopter Blade Mold
Thermwood LSAM 60mm Melt Core Initial Testing - ABS
Thermwood Validates Direct Additive Manufacturing of Yacht Hull Molds
Thermwood LSAM 3D Printed Unclassified Scale Nose of a Submarine for the US Navy
Boeing 777X Aerospace Trim Fixture via Thermwood LSAM Vertical Layer Printing
Thermwood LSAM 3D Printed Boat Hull Pattern
Thermwood 10'x20' LSAM Printing Walkthrough (Facebook Live)
Thermwood LSAM 10'x10'
Thermwood LSAM 10'x10' 3D Printing Two Parts Simultaneously
Thermwood LSAM Time-Lapse Video 3D Printing and Trimming Mold
Short Clip of Thermwood LSAM 3D Printing and Trimming Four Parts at Once
Thermwood LSAM Thermographic Camera
Thermwood at AWFS 2017
Three Generations of Thermwood CNC Routers in Action!
