Cut Ready & Cut Center: CNC with No Programming | Thermwood
Cut Ready: CNC Routing with No Programming
Cut Ready is Thermwood's cabinet production software that lets you run a CNC router with no programming. You design the cabinets, closets or furniture, and Cut Ready nests the parts, runs the router, prints part labels and guides assembly.
It comes two ways: built into the Cut Center, a 5'x10' all-in-one production system that requires neither a CNC programmer nor a trained machine operator, or as an add-on for most compatible Thermwood 3-axis CNC routers. Financing is available.
Cut Ready by Thermwood
Not Just a CNC Router - This is a Production Solution!
You have the power to create anything, with zero programming required. Thermwood's Cut Ready Cut Center is a proven cabinetmaking solution for all woodworking shops.
What Makes It Different
  • No CNC Experience Needed
  • Design ANY cabinet - no template or library limits
  • Automatic nesting, labeling, and assembly guidance
  • It's That Easy!
From cabinets and closets to moldings and stair stringers, the Cut Center handles everything: design, nesting, cutting, labeling, and even guided assembly. It's designed to deliver exactly what you want - every time.
Cut Ready is currently available two ways from Thermwood:
The Cut Center - requires neither a CNC programmer nor a trained machine operator. The Cut Center moves beyond just programming to guide the operator through the entire production process real time. Pretty much anyone can run a Cut Center.
Add-on option - Cut Ready software can be added to most compatible Thermwood 3-axis machines, depending on the machine's table size and number of tool positions. Some current Thermwood owners can also add Cut Ready to the machine they already have.
Can I Run a CNC Router Without Programming?
Yes. With Cut Ready, you never write a CNC program. You enter what you want to build, choosing any cabinet style and size with no template or library limits, and Cut Ready creates the parts, nests them on the sheet and runs the router. It then prints color-coded labels and shows you how the parts go together.
On the Cut Center, Cut Ready goes further and guides the operator through the entire production process in real time, from loading sheets to recovering from a broken tool. That's why a shop doesn't need a CNC programmer or a trained machine operator to run one.
New to CNC? See why the Cut Center is the easiest CNC router to use with no programming experience, including the full specifications and what your shop needs.
What Size Shop Is the Cut Center For?
The Cut Center comes in one size: a 5'x10' table that handles full sheets of plywood, MDF and particleboard. It's an all-in-one, self-contained system that installs quickly and can be relocated, so it fits small custom shops as well as busy production shops.
  • Shops buying their first CNC router: there's no programming to learn, and Cut Ready walks the operator through each step.
  • Shops without a CNC programmer: anyone in the shop can design a job and run it.
  • Growing shops short on labor: owners report saving one or two people's labor and running jobs after hours.
  • Custom cabinet, closet and furniture shops: design exactly what each customer wants instead of choosing from a library.
Cut Center or Cut Ready on Another Thermwood Router?
Choose the Cut Center if you want the simplest path to CNC production. Cut Ready is fully integrated, the machine guides the operator through every step, and features such as automatic vacuum pump control, precision sheet position detection and material thickness calipers are built in. No training is needed to operate it. Add the CNC Access option if you also want to program and run it as a conventional CNC router, and Thermwood will train two of your people for a week at its Advanced Training Center in Dale, Indiana.
Choose a Cut Ready-equipped 3-axis router if you need a larger table, more tooling or a different configuration. You'll still need machine training and normal router operation, apart from programming. With CNC Access, it can also run as a standard CNC router for other work. See the Thermwood 3-axis CNC router lineup. The comparison table below shows the features side by side.
What Can You Make With Cut Ready?
Custom cabinets, closets, drawer boxes, doors and drawer fronts, moldings, stair stringers and custom furniture. Because Cut Ready doesn't tie you to a template or library, you can design any cabinet you need and change it for each job.
ALT
See how easy it is to Design and Machine a Cabinet Job on the Cut Center
See how easy it is to design and machine a cabinet job on the Cut Center
Cut Ready Series Machines - Comparison
Features Cut Center Cut Ready Equipped 3 Axis Machine
CNC Programming not required
AI Inside
E-Stop Recovery Help
Cut Ready App for Job Creation
Remote Pause FOB
Label & Sheet Printers
Color Coded Job & Part Labels
Touch Screen Monitor
Automatic Tool Management
Easy Recovery from Broken Tool
Automatic Off-Fall Management
Easily Recut Damaged Parts
Wasteboard Life Notification
Automatic Small Part Management
Bar Code Reader
High-Tolerance Tool Sensor
Free Cut Ready Software Updates for Life
Auto Lubrication System
Optional
Auto Grease System
Optional
Vacuum Loss Detection
Optional
Ongoing Virtual Support Included
Optional
Pre-Set Tooling Torque Wrench
Optional
Automatic Sheet Air Assist
Optional
Sheet Flipper (back-side machining)
Optional
Sheet Handling Vacuum Pods (manual lift vacuum cups)
Included with Sheet Flipper
Optional
Material Thickness Measuring Calipers
Simplified Power Up/Down
Automatic Tool Verification
Automatic Vacuum Pump Control
Precision Sheet Position Detection
Air Knife Blow Off
Auto Retract Location Pins
Simplified Maintenance System
All in One Self-Contained Configuration
Quick Install/Relocation
Cut Ready Information Request
What Cut Center Owners Say
"We've saved a guy's labor every year we've had the Cut Center... or two guys. That's $100,000 savings a year... with that savings, it doesn't take long to pay your machine off."
Tim Richardson, Manager, Timberwood Properties, Leesburg, FL · Watch the video
"The Cut Center helped us reduce labor and material costs to be more profitable. Our sales grew 28.5% in the first year we had it."
"Anybody can walk in and run the Cut Center."
John Allan, President, Arkansas Wood Doors, Pottsville, AR · Watch the video
"Being able to go to the machine, easily pick out a cabinet or piece of furniture, plug in the size and start cutting material is huge!"
"The Cut Center will run everything you want. It doesn't get sick, it doesn't get tired, it will run at night and it won't talk back."
"You can teach a new hire how to put together the cabinets in five minutes. That alone is worth everything."
David Hallex, Hallex and Harich Cabinetry, Foley, AL (Model 43 Work Cell with Cut Ready) · Watch the video
Financing Available
Financing for the Cut Center and other Thermwood machines is available through Stearns Bank. Learn about financing options, or request Cut Ready information to talk with Thermwood about the right setup for your shop.
Cut Ready and Cut Center Frequently Asked Questions
What is Thermwood Cut Ready?
Cut Ready is Thermwood's cabinet production software that lets a shop run a CNC router with no programming. You design the cabinets, closets or furniture, and Cut Ready nests the parts, runs the router, prints part labels and guides assembly. It comes built into the Thermwood Cut Center and is available as an add-on for most compatible Thermwood 3-axis routers.
Can I run a CNC router without programming experience?
Yes. With Cut Ready, you never write a CNC program. You enter what you want to build, and the software handles nesting, tool paths, labeling and assembly guidance. The Cut Center goes a step further and guides the operator through the entire production process in real time, so it requires neither a CNC programmer nor a trained machine operator.
What size is the Cut Center, and what size shop is it for?
The Cut Center comes in one size, with a 5'x10' table that handles full sheets of plywood, MDF and particleboard. It's an all-in-one, self-contained system built for custom cabinet shops, closet companies, furniture builders and woodworking shops of any size, including shops buying their first CNC router and shops without a CNC programmer.
What's the difference between the Cut Center and a Cut Ready-equipped 3-axis router?
Both run Cut Ready, so neither requires CNC programming. The Cut Center is a fully integrated production system that requires no training to operate: it guides the operator through the whole process and adds features such as automatic vacuum pump control, precision sheet position detection, material thickness calipers and quick install and relocation. A Cut Ready-equipped 3-axis router offers larger tables and more tooling, but it still requires machine training and normal router operation, apart from programming. Either one can also be programmed and run as a conventional CNC router with the CNC Access option.
Can the Cut Center also run as a regular CNC router?
Yes, with the CNC Access option. CNC Access lets you program and run the Cut Center, or another Cut Ready-compatible Thermwood router, as a conventional CNC router in addition to running jobs through Cut Ready. It includes a week-long programming and operation class for two people at Thermwood's Advanced Training Center in Dale, Indiana.
Do I need training to run the Cut Center?
No. The Cut Center requires no training to operate, because Cut Ready is intuitive and the touch screen shows a video for each step. Training is included only with the CNC Access option, which covers CNC programming and machine operation.
Can Cut Ready be added to an existing Thermwood CNC router?
Cut Ready can be added to most compatible Thermwood 3-axis routers, including some machines already in the field. Compatibility depends on the machine's table size and number of tool positions, so contact Thermwood with your model and configuration to confirm.
What can you make with Cut Ready and the Cut Center?
Custom cabinets, closets, drawer boxes, doors and drawer fronts, moldings, stair stringers and custom furniture. Cut Ready doesn't limit you to a template or library, so you can design any cabinet you need.
Is there a mobile app for Cut Ready?
Yes. The Cut Ready app lets you browse products, create or edit jobs and send them to the machine remotely, without interrupting production.
Is financing available for the Cut Center?
Yes. Financing for Thermwood machines is available through Stearns Bank.
