A 3-axis CNC router moves the cutting tool along X, Y and Z to cut, drill and shape flat sheet materials such as wood, plastics, aluminum and composites. Thermwood builds 3-axis CNC routers in Dale, Indiana for cabinet, closet, furniture, plastics and nested-based production.
The lineup runs from the Cut Center, a complete Cut Ready production system that needs no CNC programming, to automated nesting cells and large format routers up to 10'x45'. Compare the models below, or see all Thermwood CNC routers.
| Model | Design | Table sizes | Key features | Best for |
| Model 42 | Moving table, fixed gantry | Single: 10'x5'; dual tables: 5'x5', 5'x8', 5'x10', 5'x12' | 12 HP spindle; 4-position bar tool changer | Low-profile materials, with dual tables for continuous loading |
| Model 43 | Moving gantry, fixed high-flow vacuum table | 4'x8', 5'x10', 5'x12', 5'x20' | 12 HP spindle; 11-position tool changer standard; 2,800 IPM indexing | Nested-based cabinets, closets and furniture |
| Model 45 | Heavy-duty moving gantry, fixed steel table | 5'x5', 5'x10', 5'x12', 6'x12', 7'x12' | 12 HP or 18 HP; optional dual spindles, drill bank and rotary axis | Heavy-duty nesting plus composites, tooling board and aluminum |
| Model 53 | Moving gantry, fixed aluminum table | 5'x10', 5'x12', 5'x16', 5'x20' | 12 HP or 18 HP; optional automatic load/unload | Routing and stack machining of large sheets |
| Model 63 | Moving bridge, stationary table | 5'x10', 5'x20', 5'x40'; extensions up to 100' | 12 HP or 18 HP; 24" vertical clearance | Large composite parts and patterns |
| AutoProcessor | Nested-based cell with automation | 5'x10', 7'x12' | Automatic load/unload and labeling; 10-position rotary tool changer | High-volume cabinets, closets and furniture |
| Cut Center | Fully integrated Cut Ready production system | 5'x10' | No programming and no training needed; automatic nesting, labeling and assembly guidance; touch screen and bar code reader; optional CNC Access to also run as a conventional CNC | Custom cabinets, closets and furniture without a CNC programmer |
| Large Format (LFM) | Moving gantry, fixed steel table | 10'x20', 10'x30', 10'x45' | 18 HP; 5-position tool changer; dual in-line tables | Oversized sheets, large composite parts and patterns |
| MTR Series | Moving gantry, single or dual in-line tables | 5'x10', 5'x12', 7'x12', 7'x20' | 12 HP or 18 HP; large-capacity tool changer; optional second head | High-volume nested, composite and plastic sheet production |
| Roller Hold-Down Series | Moving gantry with roller hold-down | Model 53: 5'x10' to 5'x20'; Model 48: 4'x8' | 18 HP; automatic load/unload (standard on Model 48) | High-volume stack cutting of MDF, particleboard and plywood |
A 3-axis router is the workhorse of sheet-based manufacturing. Thermwood 3-axis routers are used for:
A 3-axis router keeps the tool pointed straight down, which is ideal for flat sheet work like cabinet parts, nested panels and plastic sheet parts. A 5-axis router can also tilt the tool to follow curves, trim the edges of formed parts and cut angled surfaces. If most of your parts are flat, a 3-axis router is the better value. If your parts are formed, molded or sculpted, look at Thermwood's 5-axis CNC routers. To compare the full lineup side by side, see the CNC routers overview.
Dovetail Drawers of Texas in Austin makes cabinet parts and custom drawer boxes on two Thermwood 3-axis routers, including a Model 43 5'x10' running Cut Ready software, and the shop keeps both machines running nonstop. Their story was the first episode of Thermwood's Beyond the Cut customer video series. Watch how Dovetail Drawers transformed their shop.
"There's a lot of peace of mind in running Thermwood machines."
"They're just the most reliable piece of machinery we have on our floor, period. More reliable than the forklift, more reliable than the new air compressor. You come in, hit the go button and it makes you money."
"We've saved a guy's labor every year we've had the Cut Center... or two guys. That's $100,000 savings a year... with that savings, it doesn't take long to pay your machine off."
"I could give it to my 13-year-old daughter, a cut chart right now, and she can go input it in Cut Ready."
"I've had my machine since 1998 and the service and support has been nothing but outstanding. When I call, there's always a friendly, patient voice... something you just don't get anymore."
A 3-axis CNC router moves a spinning cutting tool along three straight axes: X (left to right), Y (front to back) and Z (up and down). It cuts, drills, pockets and shapes flat sheet materials, and it can carve simple 3D shapes from the top. Industrial 3-axis routers are the standard machine for nested-based cabinet and furniture production.
Thermwood 3-axis CNC routers machine hardwoods, softwoods, plywood, MDF, particleboard, plastics, solid surface, aluminum and other non-ferrous metals, composites and tooling boards.
If most of your parts are cut from flat sheets, such as cabinet boxes, closet components, furniture panels or plastic parts, a 3-axis router is the right choice and the better value. If you need to trim the edges of formed or molded parts, cut angled surfaces or machine undercuts, you need a 5-axis CNC router.
Nested-based manufacturing cuts all the parts for a job from full sheets in one operation. Software arranges, or nests, the parts on each sheet to reduce waste, and the router cuts and drills them in a single pass. It is the most common way cabinet and closet shops use a 3-axis CNC router.
Yes. With Thermwood's Cut Ready software, you never write a CNC program. You design the cabinets, and Cut Ready handles nesting, cutting, labeling and assembly guidance automatically. On the Cut Center, a 5'x10' production system, Cut Ready is fully integrated and guides the operator through every step, so it needs neither a CNC programmer nor any training to operate. Cut Ready can also be added to most other Thermwood 3-axis routers, which still need machine training and normal router operation, apart from programming.
New to CNC? See why the Cut Center is the easiest CNC router to use with no programming experience.
Price depends on the table size, spindle power, tool changer, hold-down system, software, and automation such as automatic loading, unloading and labeling. Contact Thermwood with your materials, part sizes and production volume for a quote on the right configuration.
Thermwood designs and builds its CNC routers in Dale, Indiana, where the company has manufactured CNC machinery since 1969.
Bring us your manufacturing challenges and explore the solutions that are right for you.
