HARDWOODS - SOFTWOODS - FIBERBOARD (MDF) - PARTICLEBOARD - PLASTICS - ALUMINUM
MODEL 42
Moving table, fixed gantry CNC router primarily designed to machine low profile materials such as hardwoods, softwoods, fiberboard (MDF), particleboard, plastics and aluminum.
Featured Video
Thermwood Model 42 Dual Table CNC Carving 5 Bears Simultaneously ▶
Maximum Throughput & Precision
The Model 42's fixed gantry and moving table design offers exceptional performance for machining low-profile materials.
Rigid Gantry Design
The fixed gantry ensures a stable and rigid platform for the spindle, resulting in higher precision and a superior surface finish.
High-Production Tables
Available in single or dual moving table configurations, allowing for continuous production with minimal downtime between cycles.
Versatile Configurations
Customize your machine with dual spindles, various tool changers, and pop-up pins to perfectly match your application.
MODEL 42
Moving table, fixed gantry, CNC router primarily designed to machine low profile materials such as hardwoods, softwoods, fiberboard (MDF), particleboard, plastics and aluminum.
Available Table Sizes: Single Table: 10'x5'; Dual Tables: 5'x5', 5'x8', 5'x10', 5'x12'
Standard Features
  • 12 HP HSD Spindle (3,000-24,000 RPM)
  • 4 Position Bar Style Automatic Tool Changer
  • Fixed Gantry with Moving Solid Aluminum Table(s)
  • Intelligent Servo Drives Throughout
  • Thermwood SuperControl
Available Options
  • At the Head Automatic Tool Changer
  • 7 Position Bar Style Automatic Tool Changer
  • 2nd Head Spindle
  • Pop Up Pins
  • Automatic Lubrication
  • Automatic Tool Length Measurement
Model 42 Frequently Asked Questions
What materials can the Thermwood Model 42 CNC router machine?
The Thermwood Model 42 is designed to machine low-profile materials including hardwoods, softwoods, fiberboard (MDF), particleboard, plastics, and aluminum.
What table sizes are available for the Thermwood Model 42?
The Model 42 is available in a single table configuration (10'x5') and dual table configurations (5'x5', 5'x8', 5'x10', and 5'x12').
What spindle does the Thermwood Model 42 use?
The Model 42 features a standard 12 HP HSD Spindle with a speed range of 3,000 to 24,000 RPM.
What is the advantage of the Model 42's fixed gantry design?
The fixed gantry ensures a stable, rigid platform for the spindle, resulting in higher precision and a superior surface finish compared to moving gantry designs.
What industries use the Thermwood Model 42 CNC router?
The Model 42 is commonly used in furniture manufacturing, cabinet production, architectural millwork, plastic machining, and aluminum fabrication.
