PLASTIC SHEETS - SOLID SURFACE - NON-FERROUS - COMPOSITES - NESTED BASED
MULTIPURPOSE 45
Heavy-duty three axis available in either single or dual spindles with optional rotary axis
MULTIPURPOSE 45
Heavy-duty three axis designed for composites, tooling boards, plastics, aluminum, cabinets, wood and nested base panels.  Available in either single or dual spindles with optional rotary axis. Available Table Sizes:  5'x'5, 5'x10', 5'x12', 6'x12' and 7'x12'
  • 12 HP HSD Spindle (3,000-24,000 RPM). Optional 18 HP Spindle
  • 4 Position Bar Style Automatic Tool Changer. Optional 7 Position
  • Optional Rotary Axis (accepts stock from 8" (200mm) in diameter and up to 56" (1.4m) in length)
  • Fixed Steel High Flow Table with Moving Gantry
  • Multi-Function Table (pod system capable) (Optional)
  • At the Head Automatic Tool Changer (Optional)
  • Extended Z Clearance and Stroke (Optional)
  • Automatic Tool Length Sensor (Optional)
  • QCore SuperControl
Request More Info Brochure Free eBook CNC Investment Calculator
Machine Standard Features
  • 12 HP (9kw) Spindle
    12 HP (9kw) Spindle
    A direct driven spindle with a speed range up to 24,000 RPM.  The high-frequency spindle is cooled with an electric fan for quieter running and contains ceramic bearings for longer life and for less maintenance.  The 12 HP (9kw) spindle provides the user with a heavy duty, precision spindle which provides high performance and reliability. Standard
  • QCore SuperContro
    QCore SuperControl
    Control Nesting
    A user-friendly nesting package integrated into the Thermwood control to nest various parts into sheet stock, thus creating a better yield. Also accepts layered DXF files. Standard
  • Machine Training
    Machine Training
Machine Options
  • 18 HP (13 kw) Spindle
    The 18HP (13 kw) spindle (3,000 to 20,000 programmable RPM). Accepts HSK F63 toolholders as well as Thermwood Aggregates and is equipped with an electric fan.Optional
    This option consists of tool holder arms and five tool holders, which mount in an arc around the front of the spindle and hold the tapered tool holders. When a program calls for a tool change, the tool is automatically changed at the head. Available for the primary head as well as an optional secondary head. Optional
  • 2nd Head Spindle
    2nd Head Spindle
    A second head can be added to allow simultaneous machining of two parts. The second spindle includes a complete tool slide, second servo-controlled Z-Axis assembly and 24"(600mm) space bar. (Note: Bar Style tool changer cannot be used with this option). At the head Tool Automatic Tool Changer is also available for both heads. Optional
  • 7 Position Bar Style Automatic Tool Changer
    Mounts behind the rear of the table and holds the tapered tool holders.  When the program calls for a tool change, the head moves back and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Optional
    Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Optional
  • Automatic Lubrication
    Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Optional
  • Aggregate Tooling
    Aggregate Tooling
    Allows the operator to route or drill horizontally and saw. While not in use, the aggregate tool body is stored in a tool holder located off the back of the table. Aggregate tooling adds a high level of machining flexibility. Optional
  • Drill Bank
    Drill Bank
    The drill unit is a vertical boring head with nine vertical spindles, arranged in a right angle pattern with four arranged front to back and four arranged left to right (with one additional, which is common to both). The spindles are on 32mm centers.. Optional
  • Rotary Playback
    Rotary Playback
    The rotational playback axis is attached to the top of the machine table. it is capable of accepting stock that is 8 inches (200mm) in diameter and up to 56" (1.4m) in length. The unit is designed primarily for reproducing furniture components. Optional
  • Pop-Up Pins
    Pop-Up Pins
    Guides mounted to the table perimeter for locating sheets of material. They are flipped to the up position to locate the material and then retracted to clear the area during the machining cycle. Optional
    • Vacuum Pump
      Vacuum Pump
      Universal Vacuum System is a unique method for holding panels to the table top for machining.  A sheet of particleboard or low density MDF is used as a work surface on the top fo the table.  The high flow pump vacuums through the work surface, holding the part to the table.  Pumps are available as 15HP (11kw).  Conventional vacuum also available. Optional
Videos
Traco Manufacturing Talks About Their Eight Thermwood Model 45 CNC Routers
Thermwood Model 45 5'x10' Machining Foam Board
Thermwood Model 45 5'x10' Machining Variety of Rubber with Oscillating Knife
Thermwood Model 45 with Benz Oscillating Knife Machining Foam
Thermwood Model 45 with Reciprocating Knife Machining a Variety of Materials
Thermwood Model 45 5'x10' Machining An Aluminum Sign
Thermwood Model 45 5'x10' Machining An Aluminum Pyramid
Thermwood Model 45 5'x10' Machining Aluminum Blank
Thermwood Model 45 5'x10' Machining Plastic Sheet (HDPE)
Thermwood Model 45 5'x10' Machining Carbon Fiber Reinforced Plastic
Thermwood Model 45 5'x10' Machining UHMW and Nylon
Thermwood Model 45 5'x10' Machining Phenolic Sheet
Thermwood Model 45 5'x10' Machining Small Plastic Parts with Hi-Flow Vacuum
Thermwood Model 45 5'x10' Machining Solid Surface
Thermwood Model 45 5'x10' Machining Bar Stool Leg using Optional Rotary Playback Device and Aggregate Tooling
Thermwood Model 45 5'x10' Machining MDF Doors
Thermwood Model 45 5'x10' Cabinet Cutting
Thermwood Model 45 5'x10' Solid Wood Projects
Thermwood Model 45 with Nemi Pod System Machining Poplar Hardwood Door
Machining Various Chair Components on a Thermwood Model 45
Thermwood Model 45 Machining MDF Doors
Thermwood Model 45 Machining A Pattern
