HARDWOODS - SOFTWOODS - FIBERBOARD (MDF) - PARTICLEBOARD - PLASTICS - ALUMINUM
MULTIPURPOSE 63
Large bed three axis CNC router with moving bridge & stationary table designed for two and three dimensional machining of large composite parts & three dimensional patterns.
MULTIPURPOSE 63
Available Table Sizes:  5'x10' (1.5m x 3.0m), 5'x20' (1.5mx6.0m), Table Extensions available up to 100' (18m)
  • 12 HP HSD Spindle (3,000-24,000 RPM). Optional 18 HP HSD Spindle (3,000-24,000 RPM) available
  • Fixed Solid Aluminum Table with Moving Gantry
  • 24 Vertical Extended Z Axis (Standard)
  • At the head Automatic Tool Changer (Optional)
  • 2nd Head Spindle (Optional)
  • Electric Drill (Optional)
  • 10 Position Rotary Tool Changer (Optional)
  • Automatic Lubrication (Optional)
  • QCore SuperControl
Request More Info Brochure Free eBook CNC Investment Calculator
Machine Standard Features
  • 12 HP (9 kw) Spindle
    A direct driven spindle with a speed range up to 24,000 RPM.  The high-frequency spindle is cooled with an electric fan for quieter running and contains ceramic bearings for longer life and for less maintenance.  The 12 HP (9kw) spindle provides the user with a heavy duty, precision spindle which provides high performance and reliability. Standard
    Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Standard
    Control Nesting
    A user-friendly nesting package integrated into the Thermwood control to nest various parts into sheet stock, thus creating a better yield. Also accepts layered DXF files. Standard
    QCore SuperControl
  • Machine Training
    Machine Training
Machine Options
  • 18 HP (13 kw) Spindle
    The 18HP (13 kw) spindle (3,000 to 20,000 programmable RPM). Accepts HSK F63 toolholders as well as Thermwood Aggregates and is equipped with an electric fan. Optional
  • At the Head Automatic Tool Changer
    This option consists of tool holder arms and five tool holders, which mount in an arc around the front of the spindle and hold the tapered tool holders. When a program calls for a tool change, the tool is automatically changed at the head. Available for the primary head as well as an optional secondary head. Optional
  • 2nd Head Spindle
    2nd Head Spindle
    A second head can be added to allow simultaneous machining of two parts. The second spindle includes a complete tool slide, second servo-controlled Z-Axis assembly and 24"(600mm) space bar. (Note: Bar Style tool changer cannot be used with this option). At the head Tool Automatic Tool Changer is also available for both heads. Optional
    Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Optional
  • Electric Drill
    Electric Drill
    The Electric Drill is a compact, high-powered drill which will provide the user with a useful tool for light and medium duty drilling. Optional
  • Programmable Head Spacing
    This allows dual headed machines to vary the space between the heads from 24" to 36". Optional
  • Rotary Tool Changer
    Rotary Tool Changer
    10-position Stationary Rotary Automatic Tool Changer. Optional
  • 7 Position Bar Style Automatic Tool Changer
    Mounts behind the rear of the table and holds the tapered tool holders.  When the program calls for a tool change, the head moves back and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Optional
Videos
Thermwood Model 63 5'x45' Machining Aluminum
