COMPOSITES - AEROSPACE - PLASTIC TRIMMING - NON-FERROUS METALS
MULTIPURPOSE 70
Designed for aerospace and composite applications utilizing large/heavy fixtures
MULTIPURPOSE 70
Designed for aerospace and composite applications utilizing large/heavy fixtures.
Available Table Sizes:
10'x5', 10'x10', 10'x15', 10'X20'
  • 12 HP 24,000 RPM Router with a 4 Position Automatic Tool Changing System (Standard)
  • 16 HP 24,000 RPM Router with a 4 Position Bar Style Automatic Tool Changing System (Optional)
  • 1 1/2" Thick Solid Aluminum Table (Standard)
  • Extended Z Axis: 36" vertical (Optional)
  • Extended Z Axis: 48" vertical (Optional)
  • Extended Z Axis: 60" vertical (Optional)
  • 5 Axis Chip Collection Hood (Optional)
  • Four Position Automatic Tool Changer - In Right Side Gantry Leg (Standard)
  • Ten Position Rotary Automatic Tool Changer (Optional)
  • Twelve Position Tool Bar (mounted to back of table) (Optional)
  • Automatic Lubrication System (Standard)
  • Gantry Lighting System (Optional)
  • Accu-Lube Mist Coolant System (Optional)
  • Machine Enclosure (Optional)
  • Impact Resistant Five Axis Head (Standard)
  • Continuous C Axis (Optional)
  • QCore SuperControl
Request More Info Brochure Free eBook CNC Investment Calculator
Machine Standard Features
    12 HP 24,000 RPM Router w/4 Position Bar Style Automatic Tool Changing System
    One (1) 12HP, 24,000 RPM variable speed router equipped with a four (4) position Automatic Tool Changing System. Includes four (4) ISO-30 tapered tool holders with four (4) collets, and preset tooling changing fixture. 3 positions will accept tooling up to 11.5 inch in overall length. Standard maximum tool size is 2” diameter. Standard
    Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Standard
    4 Position Automatic Tool Changer
    Four Position Automatic Tool Changer - Mounted in Gantry Leg. Includes four(4) ISO-30 tapered tool holders with four (4) collets. three positions will accept tooling up to 11.5 inch in overall length. Standard maximum tool size is 2" diameter. Standard
  • QCore SuperContro
    QCore SuperControl
  • Machine Training
    Machine Training
Machine Options
    Consists of the piping, ducting, hood(s) and swivels which attach directly to the machine (collector not included). Optional
    Ten (10) Position Rotary Automatic Tool Changer. Includes ten (10) ISO-30 tool holders and collets and a pre-set tool holder fixture. (may instead include (10) HSK F63 tool holders/collets for an additional charge). Optional
    Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Optional
  • Remote Start/Stop Pedestal
    A remote pedestal with start/stop switches and a 30 foot cable. Optional
    • High quality bright quad row LED lights mounted in a weather resistant enclosure and designed for tough environments. The unit is mounted under the gantry for better examination of finished parts and illuminating the work envelope when programming at the machine. Optional
  • Vacuum Pump
    Universal Vacuum System is a unique method for holding panels to the table top for machining.  A sheet of particleboard or low density MDF is used as a work surface on the top fo the table.  The high flow pump vacuums through the work surface, holding the part to the table.  Pumps are available as 15HP (11kw).  Conventional vacuum also available. Optional
Videos
5 Axis Demonstrations
Thermwood Model 70 10 Position Rotary Automatic Tool Changer
Thermwood Model 70 Continuous C-Axis Rotation Modeling
