NESTED-BASED • COMPOSITES • PLASTIC SHEET • CABINET PRODUCTION
MTR SERIES
High-Volume 3-Axis CNC Routing System
Featured Video
MTR Series Overview ▶
MTR Series Overview
A High-Production System to Solve Your Challenges
The MTR is a complete CNC routing system engineered for high throughput. With superior rigidity, dual steel tables, and high-efficiency tool changers, it's designed to keep your shop productive and profitable.
Maximize Throughput & Yield
Achieve continuous production with the dual in-line table configuration, which virtually eliminates downtime. The moving gantry system allows for optimal nesting, maximizing sheet utilization and minimizing waste.
Optimized & Efficient Tooling
A large-capacity, bar-style automatic tool changer handles a wide variety of tooling for any job, reducing manual changes and speeding up production cycles.
Uncompromising Quality
Thermwood's SuperControl, combined with three-dimensional laser-compensated axis alignment and intelligent servo drives, ensures every part is machined with accuracy, consistency, and the tightest tolerances.
MTR SERIES
Complete high-volume 3-axis CNC routing system with single or dual in-line tables, perfectly suited for nested-based applications, composites, and plastic sheet material. Available Table Sizes: 5'x10', 5'x12', 7'x12', 7'x20'
Core Features
  • 12 HP HSD Spindle (3,000-24,000 RPM)
  • Fixed Steel High Flow Table(s) with Moving Gantry
  • Available in Single or Dual In-Line Table Configurations
  • Large Capacity Bar Style Automatic Tool Changer
  • Automatic Tool Length Measurement
  • Thermwood SuperControl
Available Options
  • 18 HP Spindle
  • At the Head Automatic Tool Changer
  • 2nd Head Spindle
  • Drill Bank
  • Aggregate Tooling
  • Rotary Playback Device
MTR Series Frequently Asked Questions
What is the Thermwood MTR Series CNC router used for?
The Thermwood MTR Series is a complete high-volume 3-axis CNC routing system designed for nested-based production, composite machining, and plastic sheet material processing. It is engineered for high throughput with single or dual in-line table configurations that virtually eliminate downtime between production cycles.
What table sizes are available for the Thermwood MTR Series?
The Thermwood MTR Series is available in four table sizes: 5'x10', 5'x12', 7'x12', and 7'x20'. Each configuration features a fixed steel high flow table with a moving gantry, available in single or dual in-line table setups.
What spindle does the Thermwood MTR Series use?
The MTR Series comes standard with a 12 HP HSD Spindle running at 3,000 to 24,000 RPM. An 18 HP spindle is available as an option for more demanding machining applications.
How does the Thermwood MTR Series maximize production throughput?
The MTR Series is engineered for continuous high-volume production through its dual in-line table configuration, which virtually eliminates downtime between cycles. The moving gantry system enables optimal nesting to maximize sheet utilization and minimize material waste. A large-capacity bar-style automatic tool changer further reduces manual tool changes and speeds up production cycles.
What tool changer options are available on the Thermwood MTR Series?
The MTR Series comes standard with a large-capacity bar-style automatic tool changer. An optional at-the-head automatic tool changer is also available, along with a drill bank, aggregate tooling, and a rotary playback device for added versatility.
Can the Thermwood MTR Series run dual spindles?
Yes. The Thermwood MTR Series offers an optional 2nd head spindle, allowing simultaneous machining of two parts and further increasing production throughput.
What industries use the Thermwood MTR Series?
The MTR Series is used across industries requiring high-volume CNC sheet machining including cabinet and furniture manufacturing, nested-based production, composite fabrication, plastic sheet machining, architectural millwork, and residential and commercial construction.
