CABINETS - CLOSETS - FURNITURE - DOORS - DRAWERS - MUCH MORE
CUT READY 43
High-performance three axis for nested-based custom cabinets, custom furniture and support products
CUT READY 43
The Cut Ready 43 is intended to bring the magic of Artie to a lower priced system. It features a full-sized vacuum table and, just like its big brother, doesn’t require a CNC programmer.
One major difference between the Cut Ready 43 and the Cut Center, is that with the Cut Ready 43 (as in any other CNC router), you will require machine training and will need to deal with all the areas normally associated with operating a CNC router, except programming. With the Cut Ready 43 system, Artie offers help during the production process but not quite to the extent that it does with a Cut Center.
Since this is a CNC router at its core, you are free to program and operate it as a normal CNC router if you want but the magic of Artie makes the Cut Ready 43 a whole new exciting experience!
Available Table Sizes:
5'x'8', 5'x10'
  • 12 HP HSD Spindle (3,000-24,000 RPM) (Standard)
  • 21 Position Bar Style Automatic Tool Changer (Optional)
  • Fixed Steel High Flow Table with Moving Gantry (Standard)
  • Single Vacuum Zone, dual high-flow plumbing ports and pneumatic open/close switch (Standard)
  • High-Tolerance Automatic Tool Length Measurement (Standard)
  • Total Automatic Lubrication System (Standard)
  • Automatic Pop-Up Pins (Standard)
  • Printer Box with Sheet and Label Printers (Standard)
  • Bar Code Reader (Standard)
  • Solid State Hard Drive (Standard)
  • Touch Screen Control (Standard)
  • Cut Ready Tool Kit (Standard)
  • Personal Pause Button (Standard)
  • Virtual Service (Optional)
  • 15 HP Vacuum Pump(Standard)
  • CNC Access Machine Training(Standard)
  • Lift Vacuum Cups (Optional)
  • Three-Dimensional Laser Compensated Axis Alignment(Standard)
  • Control Nesting(Standard)
  • Siemens Intelligent Servo Drives Throughout(Standard)
  • QCore SuperControl(Standard)
  • Machine Training and Installation(Standard)
  • Free Phone and Forum Support(Standard)
Request More Info Compare Brochure
Free eBook CNC Investment Calculator
Machine Standard Features
  • 12 HP (9kw) Spindle
    12 HP (9kw) Spindle
    A direct driven spindle with a speed range up to 24,000 RPM.  The high-frequency spindle is cooled with an electric fan for quieter running and contains ceramic bearings for longer life and for less maintenance.  The 12 HP (9kw) spindle provides the user with a heavy duty, precision spindle which provides high performance and reliability. Standard
  • Pop-Up Pins
    Pop-Up Pins
    Guides mounted to the table perimeter for locating sheets of material.  They are flipped to the up position to lacate the material and then retracted to clear during the machining cycle. Standard
    High-Tolerance Automatic Tool Length Sensor
    Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Standard
    QCore SuperControl
  • Printer box with sheet and label printers
    Printer box with sheet and label printers for part identification. Printer system accepts information from all cabinet software capable of producing Job Level Interface output using the Thermwood QCore SuperControl nesting capabilities. The printers also operate using input from CAD software that generates properly formatted DXF format files. Also has room to store extra tools.  Standard
  • Bar Code Reader
    Bar Code Reader
    Allows you to identify or remake parts. You do not need to develop a CNC program just to remake parts. At the end of a job, simply scan the label on any part or parts and it nests them on the remaining material and cuts them. You can remake parts from a previous job the same way..  Standard
    A superior type of mass storage device with no moving parts, (which is why they are called solid state drives or SSDs. SSDs store data using flash memory.  Standard
    Control Nesting
    A user-friendly nesting package integrated into the Thermwood control to nest various parts into sheet stock, thus creating a better yield. Also accepts layered DXF files.  Standard
    Modern, touch screen control for quick access to your machine.  Standard
    Cut Ready Tool Kit
    Kit contains 1 each of the following tools
    CRT0001 - 3/8" Compression (Long Up Cut)
    CRT0002 - 3/8" Compression (Short Up Cut)
    CRT0003 - 1/4" Compression
    CRT0004 - 5mm Up Spiral
    CRT0005 - 1/8" Up Spiral
    CRT0006 - 1/2" Material Dovetail Bit
    CRT0007 - 3/8" Ballnose
    CRT0008 - 1/4" Ballnose
    CRT0009 - 1/8" Ballnose
    CRT0010 - 1/16" Down Spiral
    CRT0011 - Engraving Tool
    Standard
    Thermwood has developed a remote wireless "Pause Button" which can be clipped to a belt or pocket.  Pressing this button stops the machine in place. Standard
  • Vacuum Pump
    Vacuum Pump
    Universal Vacuum System is a unique method for holding panels to the table top for machining.  A sheet of particleboard or low density MDF is used as a work surface on the top fo the table.  The high flow pump vacuums through the work surface, holding the part to the table.  Pumps are available as 15HP (11kw).  Conventional vacuum also available. Standard
  • Machine Training
    We are by your side during your 5 Day CNC Access training course at our modern, state of the art center (devoted specifically to educating our customers). This is, by far, the fastest and most efficient way to learn. Our machine operator/programmer courses are located adjacent to the machine training lab, where students complete the prescribed projects on a specific training machine utilized only for training purposes. Then, when it comes time for practical applications on a full sized machine, Thermwood's training lab is equipped with a CabinetShop 45 outfitted with all major options and features. Real production-type parts are cut. What a confidence builder!  Standard
Machine Options
  • Lift Vacuum Cups
    Lift Vacuum Cups
    Two manual lift vacuum cups, one per side, for ease of moving sheet material. Includes two vacuum cups, vacuum cup holders and all necessary vacuum plumbing. Optional
  • Pause Mats
    Pause Mats
    Placed around the front perimeter of the machine.  Once the mat is stepped on, the machine will stop operation. Optional
  • Automatic Lubrication
    Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Optional
  • Bar Style Automatic Tool Changer
    Mounts behind the rear of the table and holds the tapered tool holders.  When the program calls for a tool change, the head moves back and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Optional
  • Virtual Service
    Virtual Service
    When the "Virtual Service" link is established, the customer can see and talk to the Thermwood service technician and the service technician can see, not only the customer, but also all of the critical parameters of the control. It essentially gives the service technician as much information as standing in front of the customer's control itself. Through this link, the control can be diagnosed in real-time while programs are being executed and corrections can be made. Programming errors can be found and corrected on-line.  Optional
Videos
Thermwood Cut Ready 43 Machining Door and Drawer Front Using Diamond Tooling
Cut Ready Series Machines - Comparison
Features Cut Center Cut Ready 43
• CNC Programming not required
• Artie Inside
• E-Stop Recovery Help
• Cut Ready App for Job Creation
• Remote Pause FOB
• Label & Sheet Printers
• Color Coded Job & Part Labels
• Touch Screen Monitor
• Automatic Tool Management
• Easy Recovery from Broken Tool
• Automatic Off-Fall Management
• Easily Recut Damaged Parts
• Wasteboard Life Notification
• Automatic Small Part Management
• Bar Code Reader
• High-Tolerance Tool Sensor
• Free Cut Ready Software Updates for Life
• Auto Lubrication System
Optional
• Auto Grease System
Optional
• Vacuum Loss Detection
Optional
• Ongoing Virtual Support Included
Optional
• Pre-Set Tooling Torque Wrench
Optional
• Automatic Sheet Air Assist
Optional
• Sheet Handling Vacuum Pods
Optional
Optional
• Easy Sheet Flipping System
Optional
• Material Thickness Measuring Calipers
• Simplified Power Up/Down
• Automatic Tool Verification
• Automatic Vacuum Pump Control
• Precision Sheet Position Detection
• Air Knife Blow Off
• Auto Retract Location Pins
• Simplified Maintenance System
• All in One Self-Contained Configuration
• Quick Install/Relocation
