MoldPlus
Core and Cavity Separation (SolidSEP)
Easily separate core and cavity geometry from complex surface or Solid models. This excruciating task that once took hours can now be done automatically in a matter of minutes in comparison to hours or days. SolidSEP literally pays for itself the first time you use it!
Draft Angle Analysis
Eliminate prototypes and tedious verification with Draft Angle Analysis. Automatically verify if your part can be machined and pulled correctly without generating a toolpath! Easily identify and isolate areas with undercuts. Surfaces are also automatically trimmed for easy knock-out construction.
Parting Line creation
Create parting curves/lines for your parts at any user-defined angle.
Parting surface / Run-off Surface
Create parting surfaces with astounding rapidity. Create 1-click automatic run-off surfaces by defining the mold boundary! Define direction lines to control the parting surface direction. Create parting surfaces using the manual method by defining the edge of the mold and selecting the surface edges to extend. Create complex corner parting surfaces with superior ease.
Automatic Moldlocks
Create moldlocks on the corners of mold inserts as side or corner locks.
Surface Edge Extension tools
Easily extend the edges of surfaces\trimmed surfaces tangentially or relative to any defined angle from the surface normal.
2D and 3D Edge creation tools
Automatically create curve edges only on the outside of the part or on selected surfaces. The part edges can also be projected onto a plane (as 2D edges) for use in contour machining or other reference geometry creation. This powerful function can also be used to verify if all surfaces are coincident.
Mold Insert Creation \ Stock Electrodes
Create square, rectangular, round or free form inserts quickly and automatically. The insert geometry can be isolated, trimmed and rotated ready for machining.
Cross Sections
Create cross sectional curves across or along surface models as single or multiple sections.
Complex Surface Trimming
Trim single or multiple sets of surfaces with blinding speed. No limitations on trimming pre-trimmed surfaces! Split or delete areas of surface models using boundaries with superior ease!
Drill Centers and Planar Edges
Create planar edges and drill Centers with point and arc information automatically on surface geometry originating from a solids modeler.
Automatic Drafting Layout (ISO/ANSI/JIS)
Creates drafting ready 2D views from surface or wireframe geometry. ISO/ANSI/JIS standard drafting layouts are provided as defaults. The user can also create custom views. The created geometry can then be used for dimensioning or engraving.
5-Axis Design Kit Features - AutoSet Normals, Radius Analysis, Check Drive Selector
Moldplus 5-Axis Toolkit
V10.8 AVAILABLE FOR MASTERCAM 2017 and X9
Powerful tools for surface analysis and geometry preparation for 3 to 5-axis machining.
1-click surface normal setting, part extension, radius analysis and powerful 5-axis curve and vector creation utlities.
  • Create 5-axis curves and tilt vectors and manipulate the tilt vectors with superior ease and speed.
    Identify collisions with custom or standard tooling and rotate vectors out of collision with blinding speed!
    Move curves and vectors relative to manufacturing requirements with easy graphical tools!**
    • Automatically set Surface Normals to the same direction in 1-click independent of plane direction!*
      Reverse normals of all faces in 1-click!
  • Seperate inner and outer shell faces independent of plane direction!*
  • Instant drive and check surface selector for machining*
  • watch video>> Check/Drive Surface Selector Video
    • Instant Radius analysis to identify and isolate user defined radii!*
    • Automatically close gaps between trimmed surfaces in 1-click!*
    • Manipulate the UV direction of surfaces by rotation or flipping them!*
    • Create stock blocks from large parts using powerful graphical tools!**NEW**
    • 1-click part extension tool (with tangent and draft faces) for 5-axis trimming or pattern making**
Contact Joe Harger, Thermwood's Software Product Manager, at 1-800-533-6901 for more information
Focus of the Software Group
To provide proven products and solutions to fit almost every application and every budget.
Why buy From Thermwood?
We've evaluated the software, know the applications, solved integration problems, developed the training and provide the software and control support.
Software Training
Thermwood conducts factory training in a dedicated classroom that provides a high level of "hands on" experience.
