AEROSPACE -SATELLITES - PANELS
APM - Aerospace Panel Machine
Designed for panel machining and automated insertion for the aerospace and satellite industries. The Thermwood APM 6'x10' is a high-performance machine that speeds up the insertion process from months to hours.
Designed for quick insertion of threaded fasteners into panels for the aerospace and satellite industries. The Thermwood APM 6'x10' is a high-performance machine that speeds up the insertion process from months to hours.
Available Table Sizes:
6'x10'
  • 18 HP HSD Spindle (3,000-24,000 RPM) (Standard)
  • 6 Position Bar Style Automatic Tool Changer. (Standard)
  • 1/2" Thick Gridded Aluminum Vacuum Table with Moving Gantry (Standard)
  • At the Head Automatic Tool Changer (Standard)
  • Wireless Position Verification (Standard)
  • (1) One Vibratory Feeding Systems (Standard)
  • Glue Station (Standard)
  • Robotic Transfer Arm (Standard)
  • Pop Up Pins (Standard)
  • Absolute Linear Encoder (Standard)
  • Automatic Tool Length Sensor (Standard)
  • Automatic Lubrication (Standard)
  • QCore SuperControl
Request More Info Free eBook CNC Investment Calculator
Machine Standard Features
  • 18 HP 3,000 to 24,000 RPM SPindle w/Five Position At the Head Automatic Tool Changer
    18 HP 3,000 to 24,000 RPM Spindle w/Five Position At the Head Automatic Tool Changer
    One (1) 18HP, 3,000-24,000 RPM variable speed router equipped with a five (5) position at the head automatic tool changer. Maximum tool diameter is 2" and maximum length is 3". Includes five (5) HSK F63 tapered tool holders and five collets. Standard
  • 1/2" Thick Gridded Aluminum Vaccum Table
    1/2" thick aluminum gridded table. 23/64" diameter vacuum hold holes spaced at 90 mm centers. Accepts all major brand vacuum pods. Removable vacuum plugs and magnetic wand included. Standard
  • Three (3) Vibratory Feeding Systems
    One (1) Vibratory Feeding Systems
    1 Vibratory Feeding System to feed inserts. Use rate of up to 10 inserts per minute. Part Position is vertical, diameter to diameter, center dowel down, single discharge. Standard
  • Glue Station
    Glue Station
    Automatically puts the correct amount of glue on the inserts. Includes (1) MM25 Dual Rotor Pump 4.0, (1) MM25 Controller for DualRotor Pump, (1) MM31 Dual Cartridge Pusher, (1) Fluid Kit for 2:1 Dual Q Cartridges, (2) Pressure Sensors for MM25 Dual Rotor Pump, (2) Extension Cables for Pressure Sensor. Standard
    Automatically picks up the insert at the output of the feeders, invert the insert and rotate it under the glue outlet, then rotate it again and transfer it to the insertion tool. Standard
    The Probe device can be used to acquire X, Y, and Z positions and will mounted piggyback to the router. Note: The Probe has an operating range of approximately 50 feet. Standard
    Mounts behind the rear of the table and holds the tapered tool holders.  When the program calls for a tool change, the head moves back and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Standard
    Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws  This has two major benefits:  First, it eliminates the lubrication points which must be servided each shift.  Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing.  This allows the machine to function in difficult, dusty or hostile environments. Standard
    Provides an automatic method of measuring tool length and entering tool length offset numbers into the control.  This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit.  It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Standard
  • Pop-Up Pins
    Pop-Up Pins
    Guides mounted to the table perimeter for locating sheets of material. They are flipped to the up position to locate the material and then retracted to clear the area during the machining cycle. Optional
  • QCore SuperContro
    QCore SuperControl
  • Machine Training
    Machine Training
Videos
